Cleaning and flushing hydronic system
Steve Minnich_3
Member Posts: 42
Can anyone recommend a product that they've used to clean and flush a hydronic system? Also something to keep the ph levels in balance? The system has GB 142 boilers, the near boiler piping is copper, and then there's miles of pex.
Thanks much.
Thanks much.
For multi metal systems
I think Rhomar has the best product. It is blended to work with copper, aluminum, stainless, and PE.
www.rhomarwater.com
hrBob "hot rod" Rohr
Thank you Hot Rod. I appreciate it.0
