what is a \"sparge\" tube and can one be made?
Kevinj_3
Member Posts: 27
You will have to tap the tank 2" to 4" depending on the requirements. Also make sure the tank is not lined. Sarc makes an injector also. I have not tried the injector.
Kevin
Kevin
Sparge tube?
What is a sparge tube for steam and can they be made or do you have to order them?
Thanks
John0 -
sparge
The sparge is used to inject steam into liquid. They can be made. It might be helpful to know more about your interest in the sparge.0 -
I have a customer who is getting a cold condensate tank about 90'. Chemical guy wants 180' in the condensate tank. There are no tappings for a coil. Burner guy suggested sparge tube. only tapping available are 1/2 taps at bottom of tank 3 of them.
John0 -
