Replacing the a steam radiator air/valve
Kenneth_2
Member Posts: 2
Hi I have to replace my steam radiator air valve. The air valve I have is shape like a long cylinder but the new one I have to replace it with is shape like a bullet.(two differnt brands. The old one was Eaton Brand and the New one is Hoffman) My question does the shape make a different in the way steam will run through my house or is it that different brand make the air valve in different shapes?
air vents
Air vent shape makes no difference in the way steam will run through your system. The difference is fixed versus adjustable air vents. Adjustable allows you to vary the rate at which air wiil be expelled from the radiators and steam let in. Adjustables are better for balancing your steam/heating load. Hoffman is a well known and well regarded brand.
DAN0 -
thank you Dan
Thank You Dan,
You were right on point I replace my vent and every thing is going smooth thank so much for you advise0
- 120 Geothermal
