millivolt t-stat
ed m
Member Posts: 65
came across one of these today old system have no clue what it is also they need to replace t-stat so i went to test wires to see if it was low volt,or line and got no reading at all,h/o took out boiler manual from sears 1970 says its a self generating millivolt t-stat, how do i go about replacement do they still sell those t-stat,any help would be appericated thanks
eddie
eddie
millivolts
yes you can still find millivolt tstat a good powerpyle generator with good pilot should give you about 750 millivolts 3/4 of 1 volt reading johnstone supply has them grainger might too usually starts with ts part #0 -
Robertshaw makes one p/n 200-501
Also Honeywell vision pros for programmable are suppose to be ok with millivolts also.0 -
We use the HONEYWELL VISIONPro 8000 on millivolt systems all the time. They're great!0
- 167 Indoor-Air Quality
