CO Detectors React to What Else? (Brad White)
Brad White_185
Brad White_185 Member Posts: 265
probably two years old and was bought in addition to the hard-wired one that went in with the Vitodens in or about Nov. 2006.
(We are waiting for the hard-wired combination smoke/CO detectors so we can replace all of the 120V smoke detectors eventually.)
The plug-in is just a supplement and to comply with our "Nicole's Law" CO detector statute.
I can easily see it being at the end of a lifespan and the varnish fumes probably sent it over the edge.
  • Brad White_185
    We just had the floors refinished
    and after some time tracking down that beeping sound (thinking it was a smoke detector with a low battery), it turns out according to Susan that it was the plug-in CO detector.
    Granted the varnish is a source of hydrocarbons and CO is, in part, carbon...)
    Anyway, maybe this is common and we are curious if CO detectors react to other compounds. So many detectors are substance-specific. Curious what anyone has experienced.
    Thanks all!
    Brad
  • jp_2
    jp_2 Member Posts: 1,935
    along the same line
    I've been trying to find out what the CO sensor is?
  • ALH_4
    ALH_4 Member Posts: 1,790
    UL
    All I can find is this excerpt from this UL document.
    "Will exposure to other household gases or vapors cause the CO alarm to sound a false alarm?
    When UL evaluates samples of residential CO alarms, consideration is made that your home may contain moderate levels of cleaning chemicals and other substances. UL 2034, the Standard UL engineers and technicians use to test residential carbon monoxide alarms, includes exposure tests to normal concentrations of methane, butane, heptane, ethyl acetate (nail polish remover), isopropyl alcohol (rubbing alcohol), carbon dioxide and propane -- all gases that would typically be found in a home.
    You should, however, keep these chemicals away from your CO alarms. Low exposure over an extended period of time could damage the sensing device and cause your alarm to sound a false alarm."
    I'm not sure if that means that the sensors are particularly sensitive to those gases or not.
  • CC.Rob_6
    CC.Rob_6 Member Posts: 7
    humidity, too
    I believe that CO detectors are also sensitive to humidity extremes.
  • They especially like
    bacon being cooked in a skillet on a Saturday morning. My kids called me once as they has evacuated the house because the alarm went off as they were cooking breakfast. The CO detector will actually go off before the smoke alarm in a fire.
    For some expert info contact George Kerr at gekerr@tds.net he is the inventor of the CoExperts CO detector.
  • Mark Hunt_4
    Mark Hunt_4 Member Posts: 68
    It would be easier
    to list the things that did not set off a UL compliant CO detector.
    How old is Susan's CO alarm Brad?
    Mark H
  • John@Reliable_14
    John@Reliable_14 Member Posts: 171
    Steam, from a long shower, open door steam hits it = alarm
  • jp_2
    my guess is
    that the nighthawk and CO experts uses the same sensor.
    can't imagine there are a lot of different materials that can react to CO.
    where's jim davis on this?
  • Steve Ebels_3
    Steve Ebels_3 Member Posts: 1,291
    Ditto to Mr Hunt
    Add paint to the list, most any household cleaner in the right proximity and concentration.........and then there was this one. A lady called up reporting her CO detector was going off one morning. I went right over and everything checked out OK, stove, furnace, water heater, dryer....all of it. It was a brand new First Alert detector from HD she had just put up the day before. Told her to get a different detector, which she did. A week or so later she called and said the detector was going off again. Same result, all the appliances were OK. A little Q&A session revealed that the detector went off at the same time as the one that was replaced. 7:15 AM Hmmmmmmm ....I asked if it would be OK if I came over at that particular time of the day and observed what was going on to try and find out what was tripping the alarm. So I'm sitting there in the kitchen of the house at 7:15 in the morning with the Testo running on ambient CO and showing 0ppm and the detector goes off. I went to the hallway where it was mounted to check the air there and found the woman of the house standing there looking at the detector, which was right outside the bathroom, with a can of hairspray in her hand. BINGO! Took the detector outside to let it "cool off", then back inside and gave it a spritz of the stuff she was using. The thing went off instantly.
    This was a non aerosol pump type container so it had to be the product itself. Hairspray........whoda' thunk it!!??
  • Rudy
    Rudy Member Posts: 482
    CO alarm cross sensitivity
    Here's one manufacturer's list:
    Aerosols – (hair sprays, deodorizers, Lysol, etc…)
    Cleaning supplies – (Clorox, Bleaches, etc…)
    Gas from charging batteries
    Paints
    Stripping chemicals
    Varnish
    Silicon glue or compounds
    Alcohol
    Methane
    Toluene
    Acetone
    Nail polish
    Nail polish remover
    Sulfur compounds
    Sewer gas
    Vapors from baby diapers
    Car exhaust fumes
    Cigarette smoke
    Incense smoke
    Ammonia
    Carpet cleaning solutions
    Sealant
    Freon from air conditioners
    Hydrogen
    Nitroglycerin (usually from heart medication)
    High/Low temperatures
    High/Low Humidity
  • Brad White_185
    Thanks, Rudy
    I guess that settles it- we do not have CO detectors, we just have "detectors".
    From now on we will not use hairspray, cook bacon, shower or play "pull my finger".
    Life is good. :)
    Thank you all- this has been very instructive!
  • Timco
    Timco Member Posts: 3,040
    I didn't see CO on that list...
    Tim
    Just a guy running some pipes.
  • jackchips_2
    jackchips_2 Member Posts: 1,337
    \"No Shower?\"
    Now Brad, just how long do you think that honeymoon will last? I'll leave the "pull my finger" to Milne.
    Jack
  • Darrell
    Darrell Member Posts: 303
    Dog fumes.
    Add dogs fumes to the list...lots of calls where the dog is sleeping under the detector...he goes off...it goes off.
    Being a service man is fun sometimes!
    (The odd burrito for lunch will set off my 300 dollar belt detector)
  • Rudy
    good point
    Come to think of it, CO wasn't on the list....
  • jp_2
    thats why
    it called cross sensitivity.
