OT sewer clean up in basemnet
Jeff Elston
Member Posts: 289
Hello,
No biggy my wife ran the laundry a number of times and it block the main. So i got some drain water out the clean out and on to the floor.
I vacuumed it up and it dried out by the next day(dehumidifier and fans). Should i clean it further and if so with what?
Just looking for suggestions. If left a fine dust when it dried. Thanks again
maybe some bleach and water
This will help to sanitize where it flooded. Verify 1st that it wont hurt flooring.0 -
yea
Thats what I was thinking to,
it is bare concrete slab0 -
do not
expose yourself to bleach vapors. Ventilate the room. Bleach vapors kill brain cells.0 -
Actually, chlorine
will can scorch your lungs, not to quibble. Beer trims brain cells
A light bleach mist, 10% to 20% in water should be fine, do not over do it and do not let it get into contact with any ammonia or drain cleaners which may be present. Heck, Lysol has a spray that is ok too as well as the Chlorox cleaning spray. Does not take much but yes, ventilate.0 -
Thanks again
Thanks guys
- 167 Indoor-Air Quality
