Stackable Oil Boiler/water heater in Closet TIGHT
bill_97
Member Posts: 172
The boiler is 24 inches wide and from the back to the burner cover is less than 30 inches I believe . The 4 inch fluepipe connector is on top of the boiler . Here's a job we did in a closet . The package includes a 40 gallon storage tank powered by a flat plate heat exchanger .
Anyone have these measurements?
I have a closet job I'm looking at, swinging louver doors at each end (front/rear). I have about 44" to deal with, does anyone have the measurements memorized? Viessmann or Buderus? Oil fired on top of a small Indirect. No way a vert tank will work; it's either this or a tankless!
Thanks for any help.
GW
The
LT-160 Buderus indirect is 26Wx32L
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
44 is tight
This is 60" wide. Ron0 -
yes
I can get that stuff off the net, but I can't see the burner dimensions, and how it overhangs the water heater, etc. So, it's the burner and flue I'm wondering about. Thanks, gw
thanks
what size tank is that, and what size boiler?
how about...
EK 2000..frontier. not a huge fan but if it works....
http://www.energykinetics.com/specifications.html#frontier0 -
LT 160 and G115/210 -
You Need.....
Ron Jr.
He's expert at fitting 10 lbs of stuff into a 5 lb bag!There was an error rendering this rich post.
Hey!
Thats the combo Im thinking of getting. Your saying the closet is 60" wide? Man, these things are huge. I so wish I had gas.0 -
The flue
The flue pipe is what really takes up the additional space. But that was the price to pay for having a three pass. Besides the pipes and such have to go somewhere. Ron0 -
I second Ron Jr.
The EK boiler and hot h2o tank is a great fit for a tight space. Front door swings down for easy cleaning. Vertically integrated footprint. Probably no more than 40" or so front to back with burner. And....they are really efficient.
Rocky0 -
i too think a small EK would do the trick a like the deltas from
Triangle Tube also/ they have the foot print thing down.
the Buderus lash up i would be more comfortable with in a 54 than 44 inch access.0 -
several steel boilers would work
Burnham LE
Laars
Thermodynamics
Could always drop one on top of a horizontal tank from
crown or put next to a tall thin indirect.0 -
check out triangle tube www.triangletube.com their delta combination heater series. oil fired space heating and indirect water heating all in one unit.0 -
Hi Gary
Sometimes you just gotta use a shoehorn LOL0
- 87K THE MAIN WALL
- 114 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
