Stackable Oil Boiler/water heater in Closet TIGHT
bill_97
bill_97 Member Posts: 172
The boiler is 24 inches wide and from the back to the burner cover is less than 30 inches I believe . The 4 inch fluepipe connector is on top of the boiler . Here's a job we did in a closet . The package includes a 40 gallon storage tank powered by a flat plate heat exchanger .
