Ice Hardened
Tom Manton
Member Posts: 30
Ice Hardened
Look for a new generation of sawzall blades,hole saws and larger diameter 3 tooth "Big Hawgs" from Milwaukee tool. The process uses very low temperature hardening during manufacturing.
Supposively faster,longer lasting and cleaner holes. Saw a half hour promo last week. If they live up to their billing they should be a big improvement over present blades and drills.
Available March 15,2008
Rich K.0 -
Are the Big Hawgs
Wood self feed bits?..that would be a great innovation! I've been using Lenox hole saws / Sawzall blades for years..nothing else compares (yet!)0 -
Similar Design
The "Big HawGs" are very similar to Lenox one tooths except they have three teeth and are using their new ice hardened technology which allows over 300 holes before sharpening.
I guess you would call these a "cut above"0 -
Saw
Or you could call it a HOLE lot better.0
- 167 Indoor-Air Quality
