Direct vent termination
Derheatmeister
Member Posts: 1,659
Code or not when you vent near the "Exhaust"/ "Fart fan" /Dryer vent. Kitchen Exhaust you can have a Problem!.. say your dryer vent is stuck open, you leave the dryer door open, You have a negative pressure situation in the building i.e. a fan in the window, the Exhaust can be Drawn back into the Living paces and poison the occupiers. and yes there is such a code that states something about Vert. distance from mech.outlets not just inlets.
Would a vent hood from a bathroom or kitchen exhaust fan be cocidered a non-mechanical vent. What are the codes for venting a appliance near a exhaust hood.0 -
what are...
you venting? If its a boiler/furnace the vent directions are pretty specific. They usu. give you diagrams.0 -
vent termination
Venting a modine hot dawg heater. I know the specs for venting. but I always stop and think when I teminate close to a exhaust vent. Would like to know if anything is sated in the codes.0
