Honeywell website
to come up with in this age of electronics are pilot assemblys. In fact come to think of it they ahve always been tough to come up with it was just easier to retrofit a new replacement one with thermocouples.
I'm trying to find a Honeywell website that shows different ignitors and wondering if anyone here has a web address. What I'm looking for is the ignitor/flame rod for a G334X series Buderus boiler. The local (120 miles away) distributor does not have it and doesn't seem to know what I'm asking for. If I could identify the thing and set a P/N I could probably order it from the master Honeywell distributor and get it faster.0 -
MH website
try, honeywell.customer.com
maybe it was customer.honeywell.com0 -
No luck there
When I Google Honeywell all I get is the corporate website dealing with all their heavy industry and aerospace stuff. Oh the joy of dealing with a huge conglomerate type company.0 -
IGN/FLAME ROD
PART # Q3451E7103 available @ Goodin Co. Minneapolis. 800-328-8433. Regards.0 -
Honeywell web site
Go to www.customer.honeywell.com. Scroll down to the bottom of the page, and type in the part number in the "literature" section. You will get a PDF of the tech sheet. OEM items are not covered however, just trade products.0 -
Update
The part number someone listed here is correct for the Buderus G334X... boiler I am working on. Unfortunately, it is an OEM only piece and no one..... that's NO ONE!........in the fine State of Michigan has it in stock. I found a place in Milwaukee, Columbia Pipe and Supply, that has 4 and I ordered all of them. If any of you work on Buderus equipment it would be good to keep a couple of these in stock. I had always assumed seeing that the ignition system was Honeywell that parts would be pretty much standard. Not so.
Call me frustrated, call my customer P-O'd0 -
alternative
For the future, keep this in the back up file. They are just West of Chicago in Lisle and they often get things faster than the manufacturer. Honeywell, JCI, B&G, Belimo and many many more.
NEUCO
Mike Emory
(630) 960-3800 OFFICE
michael@neucoinc.com0 -
Honeywell Website
Is it just me or can no one else ever find anything on the Honeywell website? I have more luck Googling it and then finding the results from the Honeywell site there.0 -
honeywell
Sometimes it works real well, and other times you can't go anywhere with it. Could it be jammed by too many users at times?0 -
wiring
I have a honeywell swithing relay and the diagram peeled off and I am trying to wire up my modine wall heater and I cant remember how to wire it.YS0 -
wiring
- 167 Indoor-Air Quality
