steam
Give this a <A HREF="http://www.heatinghelp.com/newsletter.cfm?Id=29"> read </A>, perhaps it will help.<BR><BR>dave
  • paul_91
    paul_91 Member Posts: 62
    hot water zone
    im installing a hot water zone...using the water from a steam boiler. i have a few questions. is it better to use a heat exchanger or just take water from the bottom of the boiler?....and if i use a heat exchanger where is the best place to put the aquastat
