Gorton Steam System - \"connectivity\" question
bob young
bob young Member Posts: 2,177
  • Ellis Richman
    Ellis Richman Member Posts: 22
    Hello!
    Got a Gorton one-pipe steam system, about a hundred years old...Steamhead has tweaked it to great working condition.
    Just discovered that a vertical pipe running to the third floor radiator appears to be a copper pipe, and in-between the 2nd and 3rd floors someone made a connection by simply inserting one copper pipe into a larger one (slid one over the other. It's a nice slip-on fit, but here is my question:
    Is there a product that I can wipe on the pipe's end so that when I insert them together in between the second and third floors the pipe will have a better seal and be less likeley to leak steam or condensate?? I would have to rip 100 year old floor boards up to get to this area...and that's a tall order!
    THANK YOU VERY MUCH FOR ANY SUGGESTIONS!
    Ellis in Annapolis
  • gerry gill
    gerry gill Member Posts: 3,083
    you'd better have Frank
    look at it..that sounds wierd..was it some sort of expansion piece?
    gwgillplumbingandheating.com
  • Oh boy
    what some hacks wouldn't do to an old steam system.....
    Give us a call, Ellis, and let's set something up for a look-see. That needs to be replaced with a proper black steel pipe.
    BTW, check out Joseph Gorton's patent for the radiator shutoffs in your house. Go here:
    http://www.heatinghelp.com/pdfs/418.pdf
