large rad and How's that work?
thats a Teledyne unit ,wheres the picture of the B&G 60 series pump with the reverse impellar ?? primary secondary pumping --flat coil -- split --backside inlet goes to the inlet of the B&G pump, front side outlet ------- thats 1 nice looking radiator big ---a little overkill -just a little
  • Jeff Elston
    Jeff Elston Member Posts: 289
    LOOOONG Rad
    I saw this it must be the longest I have come across at least 25'
    And
    I found this brand new pipe job the other day, Its one of those copper fin boilers with the pump on the header opposite the pipe connections, HELLO!
