Emergency need 1.8-2 mil burner Tim
check Ebay. I have seen Gordon Piatt burners there
Idle hands are the devils workshop
  • tim smith
    tim smith Member Posts: 2,886
    Emergency need 1.8 - 2 Mill burner, see specifics below Tim
    Gas or gas/oil, used or new, single phase, 7" max inlet press, reverse blower for minimal clearance to floor. 15.5" centerline of burner opening to floor, for superior firebox boiler. low hi low or mod. Burner dead and need now! Thanks for replies, Tim If you might have, call me at 206-571-6269
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    how is the burner "dead" ?
  • tim smith
    Burned off blast tube & end cone, no longer available. Tim
  • oil-2-4-6-gas
    what burner??
  • tim smith
    Iron fireman gas/oil, made in the 80s and put on a
    Superior firebox boiler. This burner was a red haired step child, they made if for a little over 2 yrs and abandoned the design. They make no parts for it and I have not been able to locate blast tube/endcone assy for it.
  • jeff klaverweiden
    jeff klaverweiden Member Posts: 58
    Ebay Item number: 260316075286
  • tim smith
    Thanks to all who replied. I found a returned one at Webster,
    they are making over weekend mods and air freighting out on Tues or Wed at the latest. Tim
