Emergency need 1.8-2 mil burner Tim
jeff klaverweiden
Member Posts: 58
check Ebay. I have seen Gordon Piatt burners there
Idle hands are the devils workshop
Emergency need 1.8 - 2 Mill burner, see specifics below Tim
Gas or gas/oil, used or new, single phase, 7" max inlet press, reverse blower for minimal clearance to floor. 15.5" centerline of burner opening to floor, for superior firebox boiler. low hi low or mod. Burner dead and need now! Thanks for replies, Tim If you might have, call me at 206-571-62690 -
how is the burner "dead" ?0 -
Burned off blast tube & end cone, no longer available. Tim
what burner??0 -
Iron fireman gas/oil, made in the 80s and put on a
Superior firebox boiler. This burner was a red haired step child, they made if for a little over 2 yrs and abandoned the design. They make no parts for it and I have not been able to locate blast tube/endcone assy for it.0 -
Ebay Item number: 260316075286Idle hands are the devils workshop
Thanks to all who replied. I found a returned one at Webster,
they are making over weekend mods and air freighting out on Tues or Wed at the latest. Tim0
- 167 Indoor-Air Quality
