Temperature logger
realolman
Member Posts: 513
have to have their software to download. what form is the downloaded info. Text? numbers ? can you put it in an excel spreadsheet or only use their software?
Temperature logger
I was searching for a temperature logger for some of the work that I do and came across a neat little USB device that uses a thermocouple (which is included). It is made by a company called Lascar Electronics - they have several different types. I've ordered a couple to try them out. I thought some of you might also be interested in looking at them - go to www.lascarelectronics.com0 -
I have several Lascar devices and I am very satisfied. Very easy to download the information.0 -
It does save it in a text file so you can open it with excel if you want to. The included software is simple and you can easily print out graphs of the data.0 -
Data Logger
I have two Lascar EL-USB-2 Temp/Humidity loggers at home. I use them to keep track of the conditions in my plant room. They come with a small compact disc with the application software. Very easy to use. Data is displayed graphically.
Visit: http://www.lascarelectronics.com/data-logger/0 -
These are great! Another tool to diagnose tough problems.0 -
Lascar CO detector
The same company sells a CO logger. It does not work, If it does, it won't work for long.
I am a very unhappy customer of theirs.0 -
I had an issue with one of my temp/humidity loggers. I called the company who sold it to me and they promptly sent me a new one. So far they work just fine.0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 386 Solar
