Riello 40-series G120/G200 with the Smith Series 8
steve_173
Member Posts: 140
Does anyone have experience using the Riello 40-series G120/G200 in general? What about with the Smith Series 8? I can get the Riello from stock versus a 10 week wait on the Smith/Carlin. Any thoughts on how a conversion Riello burner would work versus the custom Carlin one for the Series 8. Carlin says the Smith/Carlin burner is a custom setup that runs a little quiter than the Ez-gas.
One possible advantage is one may be able to tweak the MBH input with the Riello to get more/less sq ft of steam if needed. The downside seems to be Smith hasn't tested it and so you don't know exactly what you are getting.
Riello F40 G 200
Not sure with the Weil Mc. But I install a pair of Buderus G115/21 one oil and the other gas. Both Riellos (G200 and Buderus preset blue Riello )and you can hear the gas combustion/air intake is a little louder. With instrctions , I did have to increase the gas input. But as always you can see the better quility over the others. And yes you can fiddle out put....There was an error rendering this rich post.
If Smith has not tested it or mentioned it in the certified instruction manual, then the combination is not certified. In Canada, you would need an onsite certification costing $$$$. In the US, if there were some sort of incident, the insurer would go after you for not installing the certified and specified burner.
Are you sure about that? Smith thought that since their boiler is certified for gas use it can be used with any gas burner of the correct input. However, they can't guarantee performance.0 -
I think the power gas are always noisier than oil. Or are you saying the G200 is noisier than other power gas burners? What about the Riello burners is of better quality?0 -
Yes. I feel it is made and designed in a higher Quality. And looks like it will be easy to service. Still new aleast with me.Louder then a Carlin ? Could not answer that.There was an error rendering this rich post.
Thanks. At least I know it isn't junk. I'm guessing Smith chose Carlin because of Carlin's location and perhaps the Riello wasn't available at the time. It is odd that Smith has taken the G8 off its website although the literature is still available.
That noise reducing cover Riello displays on its website didn't do much?0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
