How do I clean my steam system?
George_10
George_10 Member Posts: 580
on our web site www.rhomarwater.com under residential steam systems.
Your new water is probably coming in via an automatic fill.
Adding this meuch new water constantly is not good for the boiler and other metal components. Each time you are adding more oxygen which will speed up corrosion.
A good cleaning and treatment will alieviate this. Once the system is cleaned and treated, you should not have to add new water constantly.
You may need to call in a steam pro to solve your problem.
