everhot wiring
Todd_12
Member Posts: 55
http://www.heatinghelp.com/heating_howcome6.cfm
As they say, "it pays to wander off the wall"
everhot wiring
Installing everhot indirect off of gas fired steam boiler. The tank will feed one zone of radiant and one zone of baseboard. The tank will be supplied from boiler with a pump. I need some help in the wiring strategy. I would like the tank to only heat when the zones call, the house only cycles once or twice on the coldest of days and I feel maintaing 180 on boiler would be a waste in the fall and spring.I would use a argo panel for the two zones and a high limit on the tank, not sure how to control the pump on the tank or the firing of boiler. Any other suggestions on how to control would be great. Thanks.0
