Help! Try to ID cast iron baseboard types
Steamhead (in transit)
Member Posts: 6,688
and Weil-McLain made these too. Have you found any names or trademarks on yours?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Help! Trying to ID iron baseboard types
I'm trying to fit together an assortment of older baseboard rads. I know the Crane,Burnham,and Slantfin designs,But for the other profiles I cant find any reference to. Any suggestions0 -
Cast Baseboards
I went to Weil-Mclain web site.Their snug fit looks similar to the Burnham line. Does American Standard make a cast iron baseboard? If so do you have a link.
Thanks0 -
That would be...
The Burnham BaseRay. The W/M is called Snug9, and is a bit different from the BaseRay. Bleeders on the top (where they can be reached without taking the covers/end caps off) I use and like both of them, and they both use the same tool for assembly! Chris0
