Radiant controls
Rick E
Member Posts: 3
I have installed a 3 loop systym of pex tubing in my concrete slab, I have a Takagi TK 2 Water heater and a taco 0011 circ pump and 3 taco solenoid valves for the loops. Question, what do I use for valve control and a thermostat to regulate the systym? Thanks in advance Rick
Radiant controls
I have installed a 3 loop systym of pex tubing in my concrete slab, I have a Takagi TK 2 Water heater and a taco 0011 circ pump and 3 taco solenoid valves for the loops. Question, what do I use for valve control and a thermostat to regulate the systym? Thanks in advance Rick0 -
You're going to need a stat for each zone, each compatible with the taco solenoid valve.0 -
Could you be a little more specific, brand and type of thermo state etc, Thanks0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
