How to bleed air out of oil fed baseboard heater on boiler syste
Tricia in CT
Tricia in CT Member Posts: 2
Ok, I drained the water one section coming off the boiler to replace a pipe. I have the pipe replaced. I have the water turned back on in that section. But it is not heating up. I think there is air in the system. How do I bleed the air out. I can not find any bleed valves. My husband is not going to be happy with me. :O(
  • Weezbo
    Weezbo Member Posts: 6,231
    *~/:) O Boy! :)) Have we Got to get you some help :)
    EEK! :)
    do you have heavy metal things that put out heat as well?(radiators)?
    a gizmo on the boiler that looks like a pig tail?
    because if you do...ya just might just want to call it good for the day and contact (click ) Find a professional
    on the top of the page...
  • Tricia in CT
    No, It is baseboard heat.
    And no, I don't see a pigtail on the boiler.
