Emergency Heating Service in Colorado
Derheatmeister
Derheatmeister Member Posts: 1,659
So.It appears to me that there is no one in Colorado that can provide Services in case of a total Boiler Failure . WE are talking about a emergency Mobile Boiler/Trailer that has approx 500000 Btu's (Not a portable Ground Thawer)!Most of the ones that are in this Business are talking about huge Semi Tractor Trailers. So is there such a company ???.Any input is Greatly appreciated Richard From Heatmeister.
  • Metro Man
    Metro Man Member Posts: 220
    Ach Tun Baby
    How goes it Der Heat Meister?
    Haven't heard of anyone here.
    How about hookin up a temp electric or gas water heater w/ high temp flex hose, connect to circ pump, air vent set up, open all the zones and let things constant circ.... control w/ existing t-stat or ??? Could set far enough away to work on existing. May not be best but will keep things from freezing.
    Are running into this or just trying to prepare?
    BTW - may be heading your way next week... you can buy me a beer
    Metro Man
  • tim smith
    tim smith Member Posts: 2,886
    Call a company named Tuco
    They are nation wide and rent boilers at 500mbh gas or oil. I just checked on one last week. Heres a link. http://www.tucoheat.com
  • boiler tech
    boiler tech Member Posts: 6
    why a rental ?
    is the tear out and install extra time consuming, or a problem with delivery of new unit. at 500000 btu it seems that it would be money better spent to just do a hurry up install of the new unit using high pressure flex hose and work on the piping later.
  • Derheatmeister
    Ja man from metro mann I Will treat you to some very gut bier from the High country .Dillon dam brewery has a fresh bock beer. Anyways yes i am Preparing for the disaster. we have lots of 30 something year old boilers that are on there last legs and condo complex's that do not want to change the equipment!unless it is needed ,so we all know how that goes:It's a Friday or Saturday and the boiler breaks ,The equipment breaks beyond repair and 60 Plus people need heat and hot water. So yes i am Thinking of making "The Mobile Meister heating Unit" with flex hoses so that i can just roll it in and hook them up. until a replacement can be installed the following week.
  • Derheatmeister
    Ironic isn't it Just got a call again most go! will be back on the wall later tonight.
  • Metro Man
    Hooter's
    Is the heating system down at hooters again!
    Thought you just fixed that.
    Metro Man
  • Derheatmeister
    Metro MAN.Just got back from "Hooters" 20hr later and that job is still not done must go back and check it again !!! also: I'm having some Beer delivered to you.
  • Derheatmeister
  • Metro Man
    Career
    Sounds like your making this a career. If you need help let me know. Waiting on the "E" man to come over the pass. Drinking beer and watching football this afternoon.
    Ya are you sending Der Keystone Light? Probably stronger than the girly beers your used to!
    Der Metro Miester Man
  • Derheatmeister
    E Man
    Yes the E man just left the "Meister Pad" and is hitting your way he is bringing some bottled beer (not bier) but give me a shout when your on the divide and we will have some of that johan bock @ the dam (Approx 9% alc.)
