Emergency heat
JJ_4
Member Posts: 146
They were recommended by our mechanical contractor...for temp cooling. Maybe they do heat too.
We ended up with another solution, so I did not work with them.
Supportech, Dave Hoyt, 303-892-6500
Emergency heat
Does anyone know of any company in Colorado that can (in case of a emergency) come in and hookup a boiler (approx 400,000 Btu)Portable boiler on a trailer.Thanks for any Information.0 -
All I know
is that I've seen the portable ground thawing units with lots of hose on the ground covered by a tarp. Sorry I can't help more. Kevin0 -
Check to see if you have a united rental in your area, some branches are set up for this.0 -
web search
Google temporary boilers. I'm looking for the same thing right now but looking for approx 11-1/2 million btu's. No trouble finding anything that big but the biggest proublem is most of the temporary units are setup for steam. I neet HW0 -
HX
The unit I saw in action was steam with shell and tube HX's heating the DHW and Hydronic loop... seems that anyone set up for this will be able to provide hot water...0 -
No luck so far, but thank you for the posts !0 -
Google Mobile Boilers
We have a mobile boiler fleet well equipped, we are in MA though. Good luck.0
