2 megasteamers 1 stat
Chips
Member Posts: 33
What's the best way to connect the stat to the boilers. Thanks Chips
S'tats
Why 2 boiler ,1 stat .Maybe a 2 stage stat .0 -
White Rodgers
has a t-stat that will call in supplemental heat. Sounds like a good fit.0 -
I am setting up a dual boiler system 1/3, 2/3. I just need to know how to jump the stat on a MegaSteamers to by-pass one of the transformers (I think)on one of the boilers. Chips0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
