PRESTIGE SOLO 110
What seems to be the problem?<BR>On the bottom are 3 pipes, 1 is the return from the indirect & CH system, 1 is the indirect tank supply and the other is the CH supply.<BR><BR>Dave
DOES ANYONE HAVE KNOWLEDGE INSTALLING A TRINGLE TUBE
PRESTIGE SOLO 110 NAT GAS BOILER0 -
LOOKING FOR SOME PICTURES OF THE INSTALL0 -
plenty of people here do them why do you ask?0 -
prestige solo 110 NAT
NOT UNDERSTANDING THE SUPPLY & RETURN ON THIS UNIT.
DIRECTIONS ARE NOT CLEAR.G0 -
What are the gauges for? Temp and Pressure? Just wondering because it looks like two of the same gauge relatively close to each other. Would one do?0 -
MPH
Temperature only, and one is on supply, other on return side.
Customer wanted these to check his own D/T as he was not comfortable fiddling with the display board.
Dave0 -
Very Nice
I just installed one this week, my first, quite an interesting unit. The closeness of the piping underneath caused me to mumble a few curses a few times. And the directions for the Smart-40 being spliced into the indirect wiring kit, an option, were not too clear. A nice boiler, but time will tell. Any suggestions for simplifing the install or what might be added to improve the job? I did not use the primary/secondary circut, per TTs suggestion, due to large existing pipes, low head/high mass.0 -
Jim
Kudos Jim, and I also had some "prime words" over those bottom piping connections.
If the system is copper that`s what I use, if BI then I use that.
I usually pre-install couplings or CXFe adapters(undoing inner HX connctions to do so), at my shop first, then install the service unions after my bottom drain tees on the jobsite as I find they are tough to get-at otherwise.
95% of the time, you will be fine without P/S, but watch for that 5% margin!
They really are a good outfit, and I`m confident time will prove that.
TT factory support has been very, very helpful to me anyway.
Good Luck with the product, as I said, I`m sure you wont be disappointed.
PS- If you try my method, take-note of those small HX connection gaskets!
Don`t ask how I knew that LOL.
Dave0 -
What Happened to Guy?
Does he still represent TT?
He used to be here alot.
Dave0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
