Burnham IN series
MikeyB
Member Posts: 696
I scraped the long angle black pigtail Burnham supplies and replaced it with all 1/4" brass fittings and brass angle pigtail, along with a 1/4" brass tee to mount the gauge as well, Come out of the boiler w/a 3/4" X 1/4" brass bushing a short 1/4" brass nipple than a 1/4" brass cplg than a 1/4" bras pigtail and a 1/4" brass tee on top of the pigtail, then mount the gauge on the bull then the pressuretrol on top of the tee w/a short 1/4" brass nipple, then you wont have to worry so much about the pigtail clogging up. The nipple they supply for the relief could be longer as well, maybe they are getting cheap....
anyone else have this problem
The last 3 or for I have done I have had to take apart the pigtail and put a longer nipple in. Same thing happens if you use the nipple they give you for the relief valve. Maybe I'm missing something but I don't see any other way to install the pressuretrol other than putting in a longer nipple
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
