products from AHR show
Ross_7
Ross_7 Member Posts: 577
Hey Hot Rod,
What did TT have for new product line?
One of our reps said they are coming out with a wall hung combo unit & a smaller btu version of the Prestige. Any input? I couldn't go to the EXPO this year, but I'll be there next year, it in Chicago again. TIA
Ross
    hot_rod Member Posts: 26,580
    tanks a lot
    I'll be back
  • Dan Foley
    Dan Foley Member Posts: 1,268
    Pics are
    #50 is a Triangle Tube tank in tank indirect with a solar coil. It has a larger than normal boiler side capacity, around 50 gallons i think to act as a buffer tank. About 40 in the inner DHW tank. Not yet available, they are still toying with tank capacities.
    51 and 52 show the HTP Contender under clear plastic.
    53 is a product to flush boilers. Add the chemicals to the toilet bowl and pump. Probably great for instantanous heater flushes.
    54 Is the Prestige HX cutaway.
    55 Shows Viega stainless ProPress stuff
