Electricity savings: 13 seer vs 14 seer?
Mitch_4
Member Posts: 955
(BTU rating / SEER) x (cost per Kw /1000) x hours of operation. = annual operating cost.
Anyone have stats or a chart that would show the energy savings of running a 14 or 15 seer ac unit vs a 13 seer job, all other things being equal? System is a 3 ton split.0 -
You need more info
before you can calculate savings. We use 1100 hours of run time in my area to calculate cost of operation. It is difficult to sell higher efficiency AC by savings. The difference between 13 & 15 seer in my area is about $20/year. Not much of a selling point. But electricity is slated for deregulation in PA in 2010. If rates increase from 8.5 cents/kwh to 12+ cents/kwh, savings go up too.
Ken
SEER calcs
A 10 SEER gets 10 btus/watt, 12 SEER = 12 btus/ watt, 14 SEER= 14 btus /watt. Carry the numbers out by a thousand and you get the btus/kw. Find the average AC run time/season for your locale and you'll get the btus /season and also the kwh used, multiply by the $/kwh and voila!, cost per season.0 -
That is great! Much thx. I live in VT, havent had much a/c season this summer so far. Where would I find the a/c run times for my geographic area? Our elec. rate is 13cents/kw.0 -
On Average
On average, a one-point increase in SEER will result in a savings of approximately 10%.
So, a 13 SEER system should produce, on average, a 30% savings in energy consumption.There was an error rendering this rich post.
Compare Warranty
Sometimes the higher seer units have a better warranty that is included in the price. Sometimes it's just a longer parts warranty, sometimes it may include labor as well as parts. The lower seer units don't always have the top of the line extended warranty program, you have to buy it seperate.
I always recommend to check on the next one or two higher seer units, just to compare warranty. For instance, a 16 seer unit might cost about the same as a 13 seer unit, if you figure in exteneded warranty programs. And you get the life long higher efficiency to boot. Just make sure it's a warranty through the manufacturer, that will apply no matter who works on the unit, as long as it's an authorized dealer.0 -
It looks like we have about 400 cooling degree days where I live. How do I convert this to kw of elec. used or hours of cooling needed so I can calculate run times? I will also look into the warranty issue. Thx0 -
Savings calculator
Here is exactly what you need. There are more where that came from.0 -
Savings calculator
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4GGIH_enUS248US248&q=air+conditioning+savings+calculator0
- 109 Chimneys & Flues
- 971 Plumbing
- 386 Solar
- 17 Recall Announcements
