piping new bath
Ken_8
Ken_8 Member Posts: 1,640
The street (or well) pressure is under 30 # and the house has the up-upstairs bath 30 feet above grade (:-o)
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=68&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • D lux_2
    D lux_2 Member Posts: 230
    bath room 15 year project
    Need some advice I have ruffed in new bathroom 2nd floor tub shower W/C toto and sink . I ran 3/4 copper Hot And cold with a hot water ½ return water tanks 50 / 60 feet away . I only stubbed to basement . ran a separate 1’’ to W/C thought about commercial flush to save room and quick fill but have changed mind and going with a toto one piece . Have a 3/4 service line 58 psig . I was thinking about installing a rinnai near the bath runs 1st floor and 2nd close to each other wouldn’t need to run return back to HWT. Rinnai wants ¾ to feed . My main question would I gain anything if I ran a 1'' feed to the bath rooms and rinnai or would 3/4 be ok 1’’ run would be 35 feet 4 to 5 ells.Service line 3/4 THANKS
  • gerry gill
    gerry gill Member Posts: 3,083
    since your service line
    is 3/4'' you wont really gain anything by running the 1'' pipe except a lower friction loss, which probably isn't much in a house anyhow..
    gwgillplumbingandheating.com
  • Robert O'Connor_12
    Robert O'Connor_12 Member Posts: 728
    D lux
    If you are only feeding two fixtures with hot water, I'd reduce it to 1/2" unless your shower valve either calls for 3/4" in the manufacturers specs, or you have multible body sprays. You don't need 1" in a domestic residential application.
    Robert O'Connor/NJ
  • jeff_51
    jeff_51 Member Posts: 545
    if you have three fixtures in the same room
    you only need half inch. unless of course as has been previously stated the t&s valve has 3/4 tie ins. Using bigger lines just means you have to move more water to get hot water to the sight. Yes yo are using a recirc, but over sizing is just as wrong as undersizing. In a residence we do now use one inch to where the water heater cold inlet tees off, but in most applications that is all you should need.
