Emergency heat
JJ_4
JJ_4 Member Posts: 146
They were recommended by our mechanical contractor...for temp cooling. Maybe they do heat too.
We ended up with another solution, so I did not work with them.
Supportech, Dave Hoyt, 303-892-6500
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Emergency heat
    Does anyone know of any company in Colorado that can (in case of a emergency) come in and hookup a boiler (approx 400,000 Btu)Portable boiler on a trailer.Thanks for any Information.
  • Kevin O. Pulver
    Kevin O. Pulver Member Posts: 380
    All I know
    is that I've seen the portable ground thawing units with lots of hose on the ground covered by a tarp. Sorry I can't help more. Kevin
  • Home Depot Employee
    Home Depot Employee Member Posts: 329
    Check to see if you have a united rental in your area, some branches are set up for this.
  • Rich L.
    Rich L. Member Posts: 414
    web search
    Google temporary boilers. I'm looking for the same thing right now but looking for approx 11-1/2 million btu's. No trouble finding anything that big but the biggest proublem is most of the temporary units are setup for steam. I neet HW
  • Hvacman
    Hvacman Member Posts: 159
    HX
    The unit I saw in action was steam with shell and tube HX's heating the DHW and Hydronic loop... seems that anyone set up for this will be able to provide hot water...
  • Derheatmeister
    No luck so far, but thank you for the posts !
  • toolman_tim
    toolman_tim Member Posts: 8
    Google Mobile Boilers
    We have a mobile boiler fleet well equipped, we are in MA though. Good luck.
