snow melt manifolds
Steve Ebels_3
Steve Ebels_3 Member Posts: 1,291
You can of course, do anything you want. If you build your own make sure to include isolation valves on each loop and a balancing valve on the return side. Flow meters are also nice to have if you want to dial the system in for proper flow. I think that once you go through the expense of adding those items to a home made manifold, you'll find that the cost of a factory made unit is pretty comparable. Send me an e-mail with what factory manifold you are looking including the price and I'll see if I can help you out. What size pex are you using?
  • jim_29
    jim_29 Member Posts: 5
    manifolds on a snow melt system
    can i make my own manifold or does the manifold from the supplier need to be used? i guess what i'm asking is what is the perpose of the manifold other than a connection point for the feed and return loops ?
  • Andrew Hagen (ALH)
    Andrew Hagen (ALH) Member Posts: 165
    Manifolds
    There aren't many manifolds made specifically for slabs. We've been manufacturing these for a while. They are powder coated 304 stainless. This one had a custom cnc machined lid.
    -Andrew
