Radiator Bolt
Big Ed
Member Posts: 1,117
They sometimes used speical bolts that would crack or split. They prevented too much tension on the pinch rods and cast sections. I have to assume they were needed for the assembly .
Bolt
Do central heating radiators have a specialized bolt? If so, where is it used and what makes it special? Does it have a special size or material standards?0
- 167 Indoor-Air Quality
