Watts Radiant Tubing
highlander
highlander Member Posts: 10
fill tubing with water test and pour. this will stop a float.If expecting freezing after pour blow water out
  • Ron Hartzheim
    Ron Hartzheim Member Posts: 7
    Watts Onix Tubing
    We are installing Watts Onix tubing for the first time in a concrete slab. What should we use to attach to the insulation below the slab. The pipe is 1 1/8" OD
    Ron in Richmond, VA
  • Dan Foley
    Dan Foley Member Posts: 1,268
  • Ron Hartzheim
    Watts Onix Tubing
    From what the GC has informed us is that the tubing will be below the wire mesh and the mesh will float when they pour the concrete. I am thinking of stapling it to the insulation below. Do they make a staple to fit over the tubing? or should I tie it to the mesh and let it float?
    Thanks,
    Ron
    hot_rod Member Posts: 26,580
    Check out the Crete-Heat product
    I used it on habitat job recently with some Onix. Simply walk it into the posts.
    I also use it on a job with some Viega Fosta pex. Quick, clean,excellent r value and vapor barrier.
    hr
