Boiler controller for 2 stage boiler
Don_175
Member Posts: 150
OK. Thanks.
Dave
Dave
Hi Carol,
We have a 300K BTU low mass boiler (gas fired) for our home (about 6000sf). (Lochinvar Efficiency +). It has a 2 stage gas valve (High fire and low fire).
It seems to shortcycle, and someone had mentioned adding a boiler controller with outside temp sensor. They had mentioned Tekmar Controls. The specifics of our system are 5 zones (3 hydroair fancoils, 1 indirect Triangle tube water heater, and a radiant zone under the plywood of our bathroom subfloor). Our boiler must maintain an inlet temp of greater than 140 degrees or we will have problems with condensing.
What would you recommend? Any paticular model? Thanks.
dave0 -
Thanks for the question
Gotta research this. I'll be back at ya soon.0 -
For outdoor reset, how about a Honeywell AQ475 for boiler control, or an AQ 675 for a mixing valve or an AQ775 for injection?0 -
Sorry Carol...hope I dont bother you with this reply...
....but a single tekmar 374 Control would provide staging of the boiler stages and mixing for boiler protection in one.
Glad to hear it. Thanks for the help!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 47 Industry Classes
