Laars Endurance
JasonR
Member Posts: 1
I am looking for a replacement unit for a Heatmaker Boiler that can fit in a 3x3 closet.
I know that Laars has a new version called the Endurance and Burnham has the Minuteman. Both use diffrent controls but basically do the same thing. Any one have any info on either of these?
Are they reliable? The Heatmaker ran for about 16 years and the coil started to leak but it is time for a new one.
Any suggestions?
Any suggestions?
what is the....
heat loss? What is the hot water need? Depending on the load a combi boiler unit might fit the bill or a wall hug condenser with a small indirect....kpc
The Endurance
Is almost a direct match, but better
(than the Heatmaker). It modulates, has the same footprint, self-venting coil, DHW plate HX. Some re-piping required as all the connections are on top. 0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
