replacing residential boilers in long island south shore
helpingothershelpthemselves_2
Member Posts: 326
Great to see Dan Holmes here . He is the best in gas the south shore of Long Island has to offer !
Because of Dan, and of course my father(plumber) I also teach (oil) in the same trade school .
Thanks Dan for all you have you done for me .
Hey Dan see you soon,
with the utmost respect as always ,
Ken Resnick
Ken Resnick
How to choose what is the most efficient unit for a home
Hello, I live in the south shore of Long Island and my home is approx. 2950 sq.ft. The home is an extended balcony-split with high ceilings many skylights, many windows, four levels and 2 fire places. The top floor never receives enough heat and the master bedroom has a garage under it and is always freezing. About the Garage area I had blown insulation put in,the garage door was replaced with the best insulated door Raynor makes. The home is approximately 50 years old is well insulated. Any advice would be really appreciated knowing how expensive heating oil has become. Many thanks in advance....0 -
Systems
You need to tell us what type system you have. Warm air,steam,hydronic and fuel use.Gas ,oil ,coal ect.
What I can tell you from your post,zoning would be your cure for the two cold areas.0 -
your heat
spent 30 years with gas co, teach in trade school in dix hills. very slow typer.call me at 631 666 5974.i to live on so shore of LI.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
