help with radiant heat
hr
Member Posts: 6,106
local fire departments, or utility companies.
Or go to the www.flir website and contact a dealer for a demo :) They may tell you if anyone has a camera in your area.
I pay $100.00 per hour to rent one. With a very skilled operator.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
looked at a screwed up radiant system today 3/4 pex to 2nd floor then viega/stadler manifolds feeding 6 runs of 5/16th pex tubing no plans left by contractor no idea how tubing is laid out is there any one in the boston area with a infrared camera
Bad
How bad can it be? Tell us.
ed
Crank up the water temp and you should be able to find them with a non contact infared theremometer . why find them though that stuff is made to be on 7" centers the pieces are pre made how could it be different than that . Where in Mass I may have already looked at it.0 -
helpwith radiant
the job is in newton ma. consist of burnham boiler,big radiators in most of the house,radiant is in the master bedroom,masterbathroom and a walk in closet
help with radiant
heres an update i visited the viega offices in bedford ma today showed them pics of the job and a diagram i made of the boiler piping there is no primary secondary piping no outdoor reset now i have to meet with customer and explain whats wrong and how to fix the mess i know have plenty of new reading material to go thru a big thank you to the viega people
- 121 Chimneys & Flues
- 15.8K Strictly Steam
