steam headers
jeff_51
jeff_51 Member Posts: 545
to much expansion and contraction, the joints will crack. It is fine on a wet return where it is below the water line, but not on the steam side. Screwed joints with swing joints and a drop header, I think you will find, is the prefered meathod on this site. If you are going to weld, them flanges are a must
  • RMA
    RMA Member Posts: 55
    copper
    what do you guys think about using copper for headers on a steam boiler?
    Pros
    Cons
    Thanks RMA
