co tester
dw
Member Posts: 5
just a question
the testers available with a probe available at my local supply house, (mass area), would they be sufficient to check the heat exchangers on a warm air system, through the plenum?
and the reading should be 0...... correct?
no tolerance for any carbon monoxide ,, correct?
thanks for the help
thanks for the help
co testers
just a question
thanks for the help0 -
co testers
just a question
the testers available with a probe available at my local supply house, (new england area), would they be sufficient to check the heat exchangers on a warm air system, through the plenum?
co testers
just a question............
Actually...Yes.
You want the usually more expensive units that give you CO, %oxygen, Efficiency, stack temp etc.. I bought a Bachrack #60 for about 400.00 to 600.00 can't remember but I love it. What I like most is I can walk into a house after the insturment warm up and detect any CO reading. Yea you can put it in the air stream, but unless the crack is huge, the readings may be eronious.....I hpoe I spelled that right....:)0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
