DHW best way
Joe Brix
Member Posts: 626
Their larger stainless steel comercial water heaters might last longer then a glass lined tank.
DHW best way
Anyone can tell me the most efficient way to make DHW for
an 22 unit apt. house (many tenants have washing machines)
The present system uses a coil below the water line in the
steam boiler ( Peerless FHA 713) with #2 oil burner This setup realy kills the steam making .
Is there a separate system also using #2 oil that would be more efficient for this task? thanks JB.0 -
I am surprised...
that a tankless coil keeps up with the hot water demand. You probably are better served witha stand alone oil fired water heater(Bock, John Wood, etc) kpc
DHW best way
Kevin: Thank you for the info, will check with Bock about a light commercial unit thanks again
JB0 -
JMO,
but I would investigate the separate heater for the summer, but not sure I'd do away with the tankless for the winter months.
If it's doing the job, it's very hard to beat a steam driven heater in the winter. Might want to have it piped so that the water heater becomes a booster in the winter.
Maybe the tankless isn't piped right if it's external? Maybe not piped right if it's internal??
These guys can help: hot water
Maybe just a new control system is in order?
This is currently shipping on more and more heaters due to it's incredible recovery capabilities: dhw control
You can always contact me too, we do have a book out on this subject: FiredragonEnt.com0 -
Firedragon: Thank you for your opinion,The coil is piped OK with a Holby mixing valve for tempering, I was just wondering if having storage would be a better approach, and I'm sure this boiler even though wet base is probably not the most efficient (the boiler runs for DHW between steam cycles) and summer operation with a more efficient system would be a great savings.
Thanks for all the help JB.0 -
How old is this setup and
what is the burner model?0 -
Firedragon: approx 20yrs old with carlin 702 burner (two stage) BTW the coil is internal handles the job but drags down the steam effort0 -
Okay, but
I'm confused by what you mean by 'the coil drags down the steam effort'. Is is because you can't run a higher water level?
One trick in the summer is to put the water level almost to the top of the glass.
A 20 year old coil has probably done it's job. I would replace it, but with an external. After three leaky indirects I went back to one in my own home, FACT!0 -
DHW bestway
firedragon: What I meant was when the boiler is in the heating cycle trying to establish pressure to trigger the timing cycle,a large demand for hot water delays the steam making.
Are you saying that an exterior coil would be a better approach to makeing hot water?
The coil is not 20yrs old it has been replaced a few times damaged by the push nipples probably because of turbulance.
Is there a way to add a storage tank to help with the DHW demand when the boiler is steaming?
I'll be looking for a more efficient means for summer operation
I prefer
external coils to internal since they have more surface area exposed to the water and also have less pressure drop. That's the technical side of it, but also find they hold up better, JMO.
Anything works better producing DHW with storage, that's a FACT! If you don't have storage you must make up for it in recovery and Btu's. Pay me now, pay me later, I like storage.0 -
Firedragon: What exactly is this external coil? Is it an Ergomax type. and do you feel your arrangement will work for a multible dwelling or how will it incorporate storage? many thanks JB.0 -
If you go back up to my
'JMO' posting and click on the hot water link it will take you to TFI-Everhot, externals have made them famous, FACT!
Ergomax is virtually a copy of this proven design that goes back almost to day one in the central heating business when Cooper& Gerstein and Everhot ruled the roost.
BTW, our host has an external in his home too!0 -
Firedragon: Thanks for your patience and help you are a great asset to this site. JB0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
