Trinity vs Munchkin
JIMBO_2
Member Posts: 127
I am getting ready to install a new boiler, gas-fired, ci radiators, 1000 sq ft of tight space, and i will probably add indiredt DHW eventually. Any ideas what boiler might be a better bet? Trinity or Munchkin? I am looking for reliability as well as efficiency. Any ideas?
Hx
is made by the same french company in bolth units , the header on the HX is different and the controls are different , use which everyone is supported better in your area , and make sure there set up using a combustion anylizer0 -
Trinitiy
You will need a Vision controller to gain outdoor reset with the Munchkin. Only certified installers can buy or install the Visions. Trinity has a larger turndown ratio and comes with outdoor reset standard. Trinity, at least from our supplier has a cost advantage. Both great machines, we have a few of each installed and no problems with either brand so far.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
