Previous contractor missed this
James mo
Member Posts: 21
Slow to heat 2 pipe steam system. OE return els' and a new vent on every radiator. 4 main air vents installed in various locations, none working. After some looking around, found this in the garage.
awesome
Great find It's been said alot of times the cause and the promblem aren't in the same room and being nosey does pay off .Great detective work get your badge peace clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
\"A new vent on every radiator\"?
> in the garage.
Sounds like you ran into a Knucklehead.
The O-E Vapor system you have doesn't use radiator vents. The air vents thru the O-E ells, into the dry return and out those vents.
Go to the Find a Professional page of this site to locate someone near you who can vent that system properly. If you're in the Baltimore area, e-mail me.0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
