If our community has helped you, please consider making a contribution to support this website.  Thanks!
Barometric dampers
                    thfurnitureguy_2
                    Member Posts: 74
                    Last year during the combustion test the tech. noted that the flue damper draft was unstable.  it varied between -.01 and + .01.  He thought that it was caused by the chimney being oversized (old coal setup) Would a barometric damper help.
            yes it would.
            Questions
 What kind of a boiler or furnace (Mfg & type of fuel)?
 Is the chimney fully lined from top to bottom?
 How large is the chimney, (how high and what size is the interior cross section)?
 Ed0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
![[Deleted User]](https://secure.gravatar.com/avatar/1b8714e1f8ac7db33a1dd00407a960a5/?default=https%3A%2F%2Fvanillicon.com%2F51437e50a93ff7ce99aa31162711f418_200.png&rating=g&size=200)
