CO tester
Firedragon_4
Member Posts: 1,434
one that will measure ambient CO, or flue gas or both?
CO detector
We are looking for a front line CO detector for our service techs. What is the best for a tech to have when he walks into a customers home? Thank you for all your help. Pray for our troops0 -
Looking for ambient0 -
Ambient CO Tester
Doug,
Link to;
www.ueitest.com/product-co71.html0 -
CO tester
Have you considered a small combustion analyzer? You can get good value with a small Kane May analyzer and if you have ever been a student at Viessmann Academy give me a call at 604-533-9445.0 -
Look at the Testo
317-3.
I've had one on my belt for two years now. It's amazing where it has gone off and even more amazing and educational is why, FACT!0 -
My former employer...
provided Ambient CO monitors made by AIM Saftey, and I loved them. Very reliable, very compact, and user servicable. Check it out at - http://www.aimsafety.com/aimsafet/products/showProduct.asp?productid=15
Otherwise, my Bacharach Monoxor II has been running ten years very smoothly. Good for ambient and flue testing, although a little large for regular ambient testing. Also I believe Bacharach still makes a portable multigas ambient tester. Check it out at www.bacharach-inc.com
As Firedragon has said, the Testo is another very good option. I haven't used one, but have ehard many good things about them.0 -
Consider.....
Doug, unless you already have full combustion analyzers on your service vehicles, Im afraid you will be disappointed with the results of using an ambient only CO instrument.
If you find ambient CO levels in a customers home, you likely need an instrument to do flue gas testing to help determine where the CO is coming from and why.
Just doing ambient CO testing may also lead your service guys and your customers to a false sense of security, just because no CO is present in the ambient air does not mean the potential for CO exposure does not exist in the flue gases of a piece of equipment.
A full combustion analyzer will typically be an instrument that can verify and document safe, efficient and reliable equipment operation (ie find more work and justify equipment replacement) to me that has a lot more potential to help grow your business.
If you are interested in hearing more (I could go on and on), feel free to give me a call a lot more info and my contact info is at www.bacharach-training.com .
JMHO
- 119 Chimneys & Flues
- 116 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
