Thermstat Recommend
RobLC
Member Posts: 93
Question for Carol Fey:
I saw your name associated with controls. We have steam heat from a gas boiler. OUr thermostat is a Honeywell Chronotherm with the mercury switch on the coil. It has a daytime and nightime setting.
Can you recommend a good, reliable, digital thermostat htat has daytime and nighttime settings that works very well with steam heat. Excuse me if we shouldn't have sent you this question.
Many thanks,
Robert
Many thanks,
Robert
Steam heat makes no difference! The newest of the programmable thermostats is the touch screen programmable. Wow, is it ever cool. That's my favorite. Next step down amoung the programmables is the TH6110. If you want non-probrammable lood at the TH5110.0
- 117 Geothermal
