can you downsize an 8\" prefab s/s chimney?
RTB
Member Posts: 8
Insulated, prefab, 20 years old, needto go to 5" for a Buderus 115 (flue temp low 300's, which is too low.), is it ever possible to line it to accomplish this, or must it be ripped out and replaced?
1- I know there are variables, I'm looking for a general answer, to give me a start
2- this is eastern LI.
Thanks
Thanks
reducing vent size
is commonly done in masonary chimneys either to line them or to match them more closely with the requirements of newer and smaller appliances. I do not see how using your oversized vent material as a chase for the new replacement vent would be any different.
Please do not assume that the vent connector on the appliance that you are considering determines the size of your vent. Always use your metalbestos tables or the tables in your local venting code to determine the ultimate vent size. If that can fit through the old vent pipe, go for it.0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
