Can I direct (side) vent a residential boiler?
Sean_10
Member Posts: 1
I have a Peerless oil burning boiler that was venting through an old chimney stack that needs to be dismantled for a number of reasons. Because of this I need to find another method of venting my boiler. The easiest way for me to do this seems to be to direct (side) vent the unit. I can't find any information in the boiler installation guide that tells me I can vent it this way.
I'm a carpenter with very little experience in thia area so any help would be greatly appreciated.
Many thanks,
Sean
Many thanks,
Sean
Yes, you can use a power vent.
> this way.
> Many thanks, Sean
direct vent
yes it can be done using a power vent from field controls
I only use Tjernlund for power venting. Their web site is
http://www.tjernlund.com/oilsidewall.htm
You want the SS2.0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
