rht pex-al pipe tubing
Weezbo
Weezbo Member Posts: 6,231
it was sent in the mail with an aluminum plate that looked something like thermo C it was like 3/16th" or so i wouldn't likely use any of it at this juncture. i would have to have a specific Need for materials requiring substantial costs to apply.
  • ed m
    ed m Member Posts: 65
    rht pex-al tubing
    any body every use this brand of pex? and if so can you use the regular round crimp rings or do you need special fittings, i used the wirsbo alum pex one time and i need to use different fittings cause the regular rings would not fit over the pipe.also is this the type of tubing when you bend it it stays in place? if anybody has any info on rht pex-al tubing i would appericiate it, friend of mine has received a good deal on it but dont know if it pays if i need to buy diffent fittings
    thanks, good luck
    Eddie
  • ed m
    rht pex-al
    dont get your meaning about the aluminum plate, this i think is like the wirsbo pex which when u bend it it stays in place,cause it has aluminum built insidr the tubing.just wanted to know if you can use same crimp rings and fittings with this pipe cause i know i had a problem with the wirsbo and had to but differnt of course more expensive fittings
    thanks
    eddie
